First Time Building!
2 hours ago, Acrobit said:-snip-
There would be no bottlenecks, everything would work just fine. Here's a list of coolers that you might consider buying instead of the one you picked. They're all pretty much equal in terms of performance and would do about as well as the one you chose.
CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler ($69.94 @ Newegg)
CPU Cooler: Phanteks PH-TC14PE 78.1 CFM CPU Cooler ($74.99 @ Newegg)
CPU Cooler: be quiet! Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler ($88.98 @ OutletPC)
CPU Cooler: CRYORIG R1 Ultimate 76.0 CFM CPU Cooler ($89.99 @ Newegg)
CPU Cooler: Thermalright SILVER ARROW IB-E 73.6 CFM CPU Cooler ($79.95 @ Amazon)
You might also consider getting a cheaper cooler if you don't plan to do crazy overclocking, in which case something like that would suffice:
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.75 @ OutletPC)
