Hello everyone, today I am bringing you a somewhat, easy question to answer (for the networking people that is). I currently have AT&T. I don't have that many ISP options where I live currently. Which is Illinois, but my internet speeds are roughly: 20 up and 2 down. We have the At&t provided modem, which I think is why my parents are complaining about internet being slow and not getting a very good signal upstairs. My Fiancee and I are in the basement with both our gaming PCs that are Ethernet connected to the modem and etc. Would everyone get a better signal and internet performance if we got an aftermarket Router like the TP-Link Archer C7 V2? Would this help with overall internet speed, or would it really just help with the Wi-Fi problem. (Also we are moving soon and I am going to set up the Wi-Fi in a more suitable area that doesn't have that much interference.
TL;DR: Modem/Router (provided by AT&T) is sitting in the basement, not a strong singal upstairs. Do I get a AP or upgrade to a good Aftermarket router like the TP-Link Archer C7 V2 with good router positioning in the new house.
https://linustechtips.com/topic/557808-router-modem-help/
I think you mentioned 20 down and 2 up but nvm that.
A new modem should fix your speed issue but also get a router placed in a better spit for better connection
Also make sure your ISP doesn't force you to use their modem, mine does.(Charter)
I have an Anet A8 as my project printer and a i3 MK3 for when I want things to work.
I extrude my own filament and haven't saved a penny yet.
My PC:
CPU: Intel i7 8700k
Motherboard: MSI Z370-A Pro
RAM: G.Skill Ripjaws V (2x8GB) DDR4-3200
GPU: GTX 1070 Founders Edition (OC'd)
Storage: 2x 2TB Seagate 5400RPM, 128GB ADATA SSD
Power Supply: EVGA Supernova 750w  B2
Cooling: Noctua NH-D15. 3 Intake Fans, 2 Outtake
Case: Fractal Design Define R6
https://linustechtips.com/topic/557808-router-modem-help/#findComment-7342967
Yeah I have currently have around 20Mbps download and 2mbps upload yeah. Yeah I am going to position the Networking in our new house more efficiently. I just want to know what kind of internet gear I should use, and upgrade to provide the best internet and networking experience to my family and I.
https://linustechtips.com/topic/557808-router-modem-help/#findComment-7342990
Oh so a specific modem and router?
Also do your know what speeds you are paying for?
My PC:
CPU: Intel i7 8700k
https://linustechtips.com/topic/557808-router-modem-help/#findComment-7343006
I believe we should be getting 24 for the download but not sure about the Upload. I can give you the specific modem and router when I get home. I am currently at school.
https://linustechtips.com/topic/557808-router-modem-help/#findComment-7343038
Ok so if you are paying for 24 down you are getting probably some of the best you will get w/o upping your plan as well as your router and modem. Since AT&T is a dsl internet provider you won't get your full of what your are paying for most times I pay for 60 down and 10 up bit I only get 50 down and 4-6 up
Edited by VoyexTech
My PC:
CPU: Intel i7 8700k
https://linustechtips.com/topic/557808-router-modem-help/#findComment-7343064
okay so I should only really just position the router to a place that everyone can get good internet and still provide the computers that need the Ethernet with that.
https://linustechtips.com/topic/557808-router-modem-help/#findComment-7343095
Correct that would be the best solution unless you are willing to pay more monthly for a better internet plan.
My PC:
CPU: Intel i7 8700k
https://linustechtips.com/topic/557808-router-modem-help/#findComment-7343110
