Just now, Deoros said:
Have you heard of Ebay?
Have you heard of being unfriendly?
You sure are sir.
See my Build here!
Intel 6700k -  Strix GTX 1080Ti - Corsair AX760 - Corsair Dominator 16GB 3000MHz - ASUS Maximus VIII Hero
Seagate Barracuda 1TB -  Samsung 120GB 840 - Samsung 840 EVO 250GB - Corsair H100i - Corsair Air 540 White -
Corsair AF120 - 2x Noctua NF-F12 - 3 x Noctua NF-S12
 Dell S2417DG - Dell UH2515H
https://linustechtips.com/topic/557110-cheap-led-strips/#findComment-7335906
You after For inside PC or for around the desk etc. ?
See my Build here!
https://linustechtips.com/topic/557110-cheap-led-strips/#findComment-7335915
I was helping out. Nothing unfriendly.
If you say so. 9_9
See my Build here!
https://linustechtips.com/topic/557110-cheap-led-strips/#findComment-7335971
Just now, GeorgeKellow said:
Both I guess. I didn't know they have to be different!
Yeah well Typically for inside the PC you want Molex or Sata.
I got some Ok ones from Maplin for £12, or for more modern ones there are the wide Beam ones from cable mod.
For the desk i'd go for something like this, Just bought them and they're great.
http://www.amazon.co.uk/Tingkam%C2%AE-Waterproof-5050RGB-Lighting-lighting/dp/B00H7T7XA2/ref=sr_1_2?ie=UTF8&qid=1456752510&sr=8-2&keywords=rgb+led
See my Build here!
https://linustechtips.com/topic/557110-cheap-led-strips/#findComment-7335995
Here you can see both the Maplin LEDs and the Ones from amazon I linked!
See my Build here!
https://linustechtips.com/topic/557110-cheap-led-strips/#findComment-7336002
See my Build here!
https://linustechtips.com/topic/557110-cheap-led-strips/#findComment-7336118
Could just get a cheap USB header to USB Type A for inside your pc and run a USB on on the inside. Second one looks better quality, however isn't RGB.
See my Build here!
https://linustechtips.com/topic/557110-cheap-led-strips/#findComment-7336133
The first on i linked you didn't looked like it could change it? Also can I cut them? what I do with the remaining lot?
https://linustechtips.com/topic/557110-cheap-led-strips/#findComment-7336140
Ahh was it literally a Red a Green and a Blue Diode aha.
Most you can they have a cut line on them.
And just throw them or keep them; could maybe come in handy at a later date.
See my Build here!
https://linustechtips.com/topic/557110-cheap-led-strips/#findComment-7336158
how do I attach them afterweards
https://linustechtips.com/topic/557110-cheap-led-strips/#findComment-7336390
I am not 100% sure in regards to the USB ones.
Would be maybe worth measuring us as they have multiple sizes and if more are needed just order as and when?
See my Build here!
https://linustechtips.com/topic/557110-cheap-led-strips/#findComment-7336422
