Hello,
I got a strange issue here.
My "S" key is not working, doesnt type at all.
The reason i am making work is because only works if i press shift at the same time.
When i press "s" some of my programs blink, so I'm not sure if i set it to do something by accident.
how can i fix this?
Thank you!
https://linustechtips.com/topic/556491-need-help-with-my-keyboard/
5 minutes ago, Luisa said:
Hello,
how can i fix this?
Thank you!
You could change the language and select it back again, to see if it works
|| CPU - i7 4790K @4.6GHz || GPU - MSI GTX 980 Gaming 4G || Motherboard - Asus Z97-A || RAM - 16GB Kingston HyperX Fury @1866MHz |Case Be quiet! Silent Base 800 ||
|| CPU Cooler - Cooler Master Hyper 212 EVO || Storage - Samsung 850 Pro 256GB & Seagate Barracuda 2TB (+ WD Caviar Green 2TB) ||
|| Mouse - Logitech G502 Proteus Core || Keyboard - Corsair K70 (MX Red) ||
1 minute ago, Luisa said:
already tried that without success. also tried to change usb ports, but nothing worked.
so it's something set on my computer for sure.
Do you have any program you use to change the actions per key (ie : Corsair Software for the K70 RGB) ?
If its mechanical, lift the keycaps and give it a nice clean. Sometimes pressing on the key for a long time will get rid of a clunky switch.
Quote me if you want me to reply.
Brand Blacklist: Gainward, Silverstone, Cougar, Gigabyte.
The keyboard is not broken, I tested and it works fine in another computer.
It's just something set and I need to fix it.
