Crash problems
Solved by Quiet_,
This will most likely be an issue with heat. There's also the idea that not all CPU's, even the same manufacturer and model, will overclock as well as another.
You can find more information about your CPU here.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113286
Here is even an overclocking guide if you would like to continue trying. Just try not to push it and make sure your temperatures are safe.
