playing GTA 5 tonight I noticed my GPU usage will drop at random times from 98%-99% to about 40%. this kills my FPS, normally I get about 85-100FPS and it will drop to about 35FPS. I cant figure out why its doing this. its not temperature realted. my GPU temp is ~60C and my CPU temp is ~45C. anyone have any suggestions on what to look into for why this is happening? I have no programs running in the backround except for MSI afterburner to monitor the GPU, ect.
heres my setup
-i7-5820k @ 3.3ghz
-Asus STRIX 980ti (not overclocked)
-16gb DDR4 RAM, quad channel mode
https://linustechtips.com/topic/555135-gpu-usage-and-fps-randomly-dropping/
My PSU is a EVGA supernova 850G2
I have already deleted the drivers in safemode using the appropriate software and did a "clean" install of the new ones, still no luck
I just played Arma 3 and watched the GPU usage, It was barely going over 35%. I couldn't even get 30FPS
Anyone have any suggestions? ive done some searching and nothing worked so far, especially in Arma 3
i monitored all my CPU cores while I'm gaming to see if maybe i was maxing out and would have to overclock, but everything seems to be okay.
