Hi, peoples LLT forums case section, I was wondering if a modular case with a bunch of frame squares (concept sketch attached) at the edge (4.5"x4.5"x0.3 "HxWxD") to  make a (18x9x22.5 inch) case. and I really want to know if there is a way I can attach the plates <3 thanks guys
https://linustechtips.com/topic/554715-3d-printed-modular-case/
I would suggest to checkout this system build, it has a similar design to what your looking into. They designed this one to where they had bolt holes that attached each corner and rail together.
https://linustechtips.com/topic/554715-3d-printed-modular-case/#findComment-7316779
looks sick only issue is the bed size of the 3d printer is only 109mm x 113mm and don't think that, or any other design for that matter would be feasible
https://linustechtips.com/topic/554715-3d-printed-modular-case/#findComment-7363973
Oh ok, that one if I remember was printed with a professional printer which gave a really nice finish but you might be able to do a modular type system similarly with dovetails or joints.
https://linustechtips.com/topic/554715-3d-printed-modular-case/#findComment-7364687
