hello i was thinking to build a new PC, and i will just use my old PC to my new office for work, so here is my current spec (its 6 years old PC)
intel core 17 930 (soket 1633LGA)
x28 EVGA SLI Classified
DDR3 triple 6GB
NVIDIA  GeForce GTX  670  ROG STRIKER  4GB GDDR5, ( p.s i just upgrade my graphic card about 2 years a go i think )
600W PSU
okay so i was thinking about this spec for my new com
Intel - Core i7 6700
Asus - Z170-A
Corsair - DDR4 16GB (2x8)
ok so here the problem, because my old PC just for work i think i dont really need good graphic card, so can i just remove my old graphic card to new one?
or i need to buy new graphic card and buy a new PSU? i will replace my old pc with some cheap graphic card,
thank you
https://linustechtips.com/topic/554572-need-come-advice/
This is the wrong forum for that sorta advise sorry man.
All jokes aside if you only need it for work just keep what parts you can to save money and maybe upgrade later if you want.
Desktop: CPU: I7-5820K GPU: 980Ti, 750Ti PhysX Mobo: MSI X99A SLI PLUS RAM: 4x4 Kingston DDR4 2400MHz OS: Win10
Storage: 250GB Samsung Evo, 3TB WD Black and Green FIRESTRIKE, Reason for dedicated PhysX Card.
Peripherals: Screen: 3x BenQ VZ2350 Mouse: Razer Naga Keyboard: Some Dell Thing Sound: Razer Tiamat, 5.1 Logitech Surround Speakers
https://linustechtips.com/topic/554572-need-come-advice/#findComment-7310184
It's fine just take the 670 from your work pc and put it into your new. Just make sure you download all the necessary drivers on your new pc with the 670. For your work pc you can just plug whatever video output on your mobo into your monitor. As for the psu, 600w will plenty. Hope this helps!!!
https://linustechtips.com/topic/554572-need-come-advice/#findComment-7310187
So you don't want to game then? That card is pretty old...
You won't notice a huge difference with that upgrade.
CPU: AMD 5950X    MB: Asus ROG Crosshair VIII Dark Hero    RAM: HyperX Predator 64GB    GPU: Nvidia RTX 3090 Ti FE    SSD: Seagate FireCuda 530 2TB
PSU: EVGA 1200w P2    COOLING: EK AIO Elite 360    CASE: Fractal Design Torrent
   DISPLAY: LG CX48 4k OLED    AUDIO: HIFIMAN Arya SE
https://linustechtips.com/topic/554572-need-come-advice/#findComment-7310191
Last time I checked, the 670 still performs quite well but if you have any budget for a capable new graphics card I suggest he should go for it. How much of your budget do you have left?
https://linustechtips.com/topic/554572-need-come-advice/#findComment-7310211
It's okay for medium to high settings depending on the game but you won't be maxing out anything at 1080p. The performance difference between the 930 and the 6700k isn't as big as one may think. It's definitely there, but I don't really see it as a game changer. I would go with something like 4790k, z97, and put the extra money into a better graphics card.
https://linustechtips.com/topic/554572-need-come-advice/#findComment-7310244
True, but the 6700k has a more consistent overclocking experience than the 4790k if you do plan on overclocking. How much money do you have left for a new GPU if you do have any left?
https://linustechtips.com/topic/554572-need-come-advice/#findComment-7310267
WOuldnt it bottleneck the cpu??
https://linustechtips.com/topic/554572-need-come-advice/#findComment-7310307
Eh, not really. It's all based on the silicon lottery. Skylake does bring some architectural improvements but they aren't really a big deal for most. Performance wise, it is only about 5% faster.
https://linustechtips.com/topic/554572-need-come-advice/#findComment-7310318
Pretty sure the 930 doesn't have integrated graphics, so he will need a standalone card.
Why? It's an i7. I have a 920 that I turned into a server but prior to that it was my main gaming rig until I built the one in my sig. I barely noticed a difference.
https://linustechtips.com/topic/554572-need-come-advice/#findComment-7310332
Nonononono....wont the 670 bottleneck the i7?
https://linustechtips.com/topic/554572-need-come-advice/#findComment-7310339
not planing to overclocking, and yeah that my max buget, in my current PC i have 2, 1 TB hard drive, and i only will use 1 later to move it to new pc, btw sry idk how to count in US dollars, because when the item move to my country its gonna be damnt expensive, thank you
https://linustechtips.com/topic/554572-need-come-advice/#findComment-7310345
This doesn't make sense lol. You're saying the graphics card would make the i7 work slower? Typically the CPU bottlenecks a GPU because it can't keep up, the i7 should do fine.
https://linustechtips.com/topic/554572-need-come-advice/#findComment-7310353
No problem, this rig will do just fine.
https://linustechtips.com/topic/554572-need-come-advice/#findComment-7310357
Other way around....say if they're playing Arma 3...won't the GPU bottleneck the CPU??
https://linustechtips.com/topic/554572-need-come-advice/#findComment-7310359
