Hi,
For my ~ 1000$US gaming/ streaming pc, I'll have an i7 5820k with r9 390 and 16 GB of RAM and also a 1 TB HD. I want an SSD, I'm thinking 500 GB? Mostly for my OS, browsing etc. among other programs as I am willing to invest in speed. But I am not very tech savvy when it comes to SSDs, all the SATA, PCi, m.2 and stuff all confuses me. Any help with choosing an SSD would be greatly helpful.
Thanks!
https://linustechtips.com/topic/554561-ssd-help/
1 minute ago, Bliznipa said:
Hi,
Thanks!
I can make you a build, but I need a few specifics:
1. Do you need peripherals? (monitor, keyboard, etc.)
2. Do you have a preference on case size?
3. preference on color?
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/554561-ssd-help/#findComment-7310068
Look at Crucial BX200, Mushkin Reactor or SanDisk. All 3 have good products and they are good pricing. In Canada you're looking at $.36 per GB which is great. US is much, much cheaper. Sigh.
Sir William of Orange: Corsair 230T - Rebel Orange, 4690K, GA-97X SOC, 16gb Dom Plats 1866C9,  2 MX100 256gb, Seagate 2tb Desktop, EVGA Supernova 750-G2, Be Quiet! Dark Rock 3, DK 9008 keyboard, Pioneer BR drive. Yeah, on board graphics - deal with it!
https://linustechtips.com/topic/554561-ssd-help/#findComment-7310094
34 minutes ago, Sportiva said:
What would your max budget be for the SSD?
I haven't decided on keyboard/monitor yet but I think I want a white ATX mid sized case. Also ideally I'd like to keep an SSD around $150 if possible
https://linustechtips.com/topic/554561-ssd-help/#findComment-7310289
http://pcpartpicker.com/part/samsung-internal-hard-drive-mz75e500bam
I dont know if you'll fit a 5820k and a 390 in $1000 if you also need peripherals
Solitaire.
https://linustechtips.com/topic/554561-ssd-help/#findComment-7310301
If your in the US then this would be what i would get http://www.newegg.com/Product/Product.aspx?Item=N82E16820147373 (I have it and it is very fast)
CPU: i5 6600k OCed to 4.5Ghz @ 1.35v, GPU: R9 390 Nitro, Motherboard: Asus z170-A, CPU Cooler: H100i GTX, RAM: HyperX 2x8 16gb DDR4, PSU: Seasonic x650, Storage: 850 EVO 500gb, WD 1tb blue, Case: H440 White/Black
https://linustechtips.com/topic/554561-ssd-help/#findComment-7310303
Yea it will be difficult with the budget, but I also planned on that budget just for the pc and not peripherals for now. I'm also considering foregoing an HDD and ssd and going with a hybrid. Or still get a 1 TB HDD and a smaller ssd. For streaming games, what sized ssd would suffice? Let's say I put the os and a couple games on the ssd
https://linustechtips.com/topic/554561-ssd-help/#findComment-7310429
Hybrid drives are obsolete, if anything, drop the HDD and stick with the 500GB SSD until you have the budget.
BTW, a few dollars (literally) more will get you the same SSD in M.2
Solitaire.
https://linustechtips.com/topic/554561-ssd-help/#findComment-7312651
Thanks guys, for now I do plan on dropping the hhd for a 500 gb ssd instead. Also is m.2 that much faster than standard? Price per performance is it worth it?
https://linustechtips.com/topic/554561-ssd-help/#findComment-7314934
I mean, it's like $2 more, and and it's smaller, takes less power and somewhat faster. Not to mention it frees up a drive bay and SATA port.
Solitaire.
https://linustechtips.com/topic/554561-ssd-help/#findComment-7318778
