Hello, i am siku and i'm looking to delve into the wonderfully exotic world of PC watercooling. I live in the united states, for pricing purposes.
PC Specs as listed:
CPU: Intel 5820k 2011v3 socket
Mobo: Asus X99 Deluxe
RAM: corsair dominator Platinum 16g 2666MHz
Graphics: x2- Nvidia GeForce 980ti GTX reference
PSU: Corsair HX1000i
Case: Corsair Graphite 760T
          now i know all that isn't needed for the loop, but my initial plan is to water cool the Cards, and CPU, this is because with the processor i have the cards sit right on top of each other due to the limit of PCIe slot pins the CPU allows. and well i figured while i'm at it lets add that CPU into the loop as well. While i am new to doing this myself, i do know basics, like what i need and hows to build it. While that might seem like "i don't need help" its not. the help i need refers to getting the best bang for my buck and what materials to avoid using for my tubing.
https://linustechtips.com/topic/554345-new-water-cooling-loop/
If this is your first custom loop and you want bang for your buck you should use flexible tubing. Hardline tubing is more expensive, harder to build, and harder to maintain.
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/554345-new-water-cooling-loop/#findComment-7307911
