hi, i m buying a new pc that will be used mainly for autocad 3dmax revit and photoshop. so no gaming :ph34r:. After hours of searching and reading i m stuck between two configurations (the diffence between them being mainly the cpu the board and the graphic card) and need help deciding :
First:
  • cpu: i7-6700K
  • board: MSI Z170 SLI plus
  • CPU fan thermaltake friosilent 14
  • memory: Hyper-X FURY (4x8gb) 32gb 2400MHZ DDR4
  • HDD: seagate 2TB 7200rpm
  • SSD: kingston HYPER-X savage 240gb
  • psu: thermaltake 750W toughpower
  • Graphic c :(MSI) Geforce GTX 980
Second:
  • cpu: i7-5930K
  • board: MSI Z99 Mpower
  • memory: Hyper-X predator (4x8gb) 32gb 3000MHZ DDR4
  • Graphic c : NVIDIA Quadro K2200
any opinion is more than welcome :)
https://linustechtips.com/topic/554118-help-choosing-between-2-configs/
The second option with a 5820k because the 5930k is absolutely unnecessary.
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
First:
  • cpu: i7-6700K
Second:
  • cpu: i7-5930K
Neither, both psus are terrible.
Then you explain why..... etc... He is new man...
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
Welcome to the forums. If you are going to do NO gaming at all then go for a Quadro series graphics card. If you do want to do some light gaming/heavy now and again dont get a quadro and stick with what you have or with what other recommend.
i can change that ... any recommendations ?
EVGA 750 G2.
The G2 line by EVGA are my go to PSU's.  I've had the 750 and the 850 and I've never had a hiccup across multiple platforms and overclocks.
Tier list, it´s tier 6:
Anything from seasonic or xfx, g2, gs, or gq psu from evga is fine as well.
