Right I need to write a program that finds the first N of factorial numbers, much like this but i need to write a function using recursion to do so.
So far I've got it working to find the factorial of one number, but i can't seem to get it too display all the first factorial numbers up to N.
Here is the code:
#include <stdio.h>
int fact (int x)
	if (x == 1) return 1;
	else return x * fact(x-1);
int main()
    int n, i;
    printf("Enter an intger number: ");
    scanf("%i", &n);
    printf("\n");
	for (i = 0; i<n; i++)
	printf("Factorial of %i is %i\n", i+1, fact(n));
And here is the output: As you can see it displays the factorial of the N only , not all the factorials up to N, as well.
https://linustechtips.com/topic/554041-first-n-factorial-numbers-using-recursion-c/
On 2/24/2016 at 6:56 AM, rEaGeNeReary said:
put a printf before the return on fact() function.
A new line printf?
On 2/24/2016 at 8:47 AM, fizzlesticks said:
You're always calculating fact(n) inside your loop instead of using the counter.
That doesn't help really. An example bit of code would be most helpful.
Mmmm...dynamic programming would help your implementation a little bit , but factorials will end up very quickly overflowing integers so I don't see much of a point for it.
Anyway , this could also work :
int n , temp = 1;
void fact(int i)
    std::cout << (temp*=i) << ' ';
    if(i<n)fact(i+1);
int main()
    std::cin >> n;
    fact(2);
:D
int n , temp = 1;
void fact(int i)
    if(i<n)fact(i+1);
int main()
    std::cin >> n;
    fact(2);
:D
I'm sorry but your soloutions are always far too complicated for me to even comprehend. I need a simple soloution that I can trace through easily. Thanks for the attempt though.
2 hours ago, madknight3 said:
Look at your loop. Look at the variable you're passing to fact(). "n" never changes, it's "i" that changes.
Well I can see that, but it still doesn't really help. I simply need someone to tell me how to do it. I already know the issue I jsut can't fix it.
What is so hard to understand? You generate 1! , print it , then generate 2! , print that one as well , and so on until you reach n!. All recursively.
You still don't know how to fix it? Come on dude. We told you fact(n) always remains constant since n never changes , and that it should have been "i" instead of "n". What more than that do you want ? D:
Your doing it in a format i'm not familaur with, using all complicated shifts and temp varaibles and that. It isn't straight foward to me. And as for knowing the problem I am trying, i've been trying for about a week.
You literally have one character wrong. To reiterate what everyone else has already said, you are printing fact(n) over and over in your for loop. n never changes, i changes. You want to print fact(i).
That's fair. He gave you an example in C++, not C, so if you're not familiar with the C++ syntax I can understand the confusion.
We are telling you how to do it.
I hope that is clear enough for you. You literally only have to change 1 letter.
Better now?
int n , factorial = 1;
void fact(int i)
    factorial*=i;
    printf("%i ",factorial);
    if(i<n)fact(i+1);
int main()
    scanf("%i",&n);
    fact(2);
