1 minute ago, 15Evan15 said:
so after i finish playing games, i will shut down my pc. All the lights and fans will turn off and i leave my room. I will come in about 20 or so mins later to find the lights are blinking indication it is in sleep mode. What is going on?
it's a ghoooossttt~~~~
You know how it is, the cow goes "moo", the dog goes "woof" and the gamer goes "The PvP is unbalanced."
Personal Computer: CPU: i7-4790 Mobo: Asrock Z97 Extreme6 Graphics Card: MSI R9-380  Memory: 16GB (8GB x2) G. Skill Sniper Gaming Series PSU: Apevia Warlock 750W Case: NZXT Phantom 410 Series Storage: 240GB SSD (OS) 3TB HDD (data and such) 500 GB SSD (Movies and Large Data Transfers (I'm constantly moving this one around to other computers))
It sounds like not only is it turning itself on but then timing out due to idle and going to sleep... all in 20 minutes... what are your power settings!?
3 minutes ago, 15Evan15 said:
how do i find them? i am very worried
It's literally called "power options".  Just search the start menu :)
2 minutes ago, 15Evan15 said:
it says:
Screen
when plugged in turn off after
10 minutes
Sleep
when plugged in, PC goes to sleep after
30 minutes
ok, so you must have been out of the room for 10 minutes longer than you thought ;)
That seems a little short, but I guess it's personal preference.
Regardless that explains why it's going to sleep, but why is it turning itself on... o.O
That could be caused by many things, almost certainly all hardware.  When I got my PC it would do the same thing, but after a while it just stopped.
i realize i had a mouse update. i updated that. also i am reading that a wifi (which i have) could be set to wake computer up
i tthink i figured it out. i read on windows forum that after doing all this stuuf there is an option for whether mouse, keyboard could wake computer. they were checked and since i needed to update mouse, it kept turning it on
That shouldn't have made it possible for the computer to cold boot itself without warning, but I guess if the problem has stopped...
