Just now, Rebornify said:
Intel Core i5-6500
MSI B150M-Bazooka
Corsair LPX 8GB
Sapphire R9 390X 8GB
Cooler Master V750 Gold
Everything seems to boot up perfectly , monitor just showing no signal , new build too . Switched monitor . Tried both the GPU VGI connector and the mobo one.
Did you try using other cables?
PC: CPU: Ryzen 5 5600X @ Curve optimzer -25,  Cooler: Noctua NH-D15 Chromax.Black, Motherboard: Asus Rog Strix B500-F Gaming WiFi II, GPU: Sapphire Nitro+ RX 7800XT @ Stock , RAM: G.Skill Trident Z RGB 2x16GB DDR4 3600Mhz CL18, HDD: Western Digital Caviar Black 2TB, SSD: Samsung 850 Evo 250GB | Team Group MP33 1TB NVME, Case: NZXT H7 Flow Black, PSU: NZXT C1200  I Peripherals: Keyboard: Ducky Shine 6 RGB Special Edition, Mouse: Razer Orochi V2, Headset: Philips SHP9500, Mousepad: Glorious Stealth Extended I Laptop: MSI GS63VR Stealth Pro CPU: i7-6700HQ@ 2.6ghz, GPU: GTX 1060, Memory: 16GB DDR4 2400Mhz, HDD: 1TB+128GB SSD
https://linustechtips.com/topic/553539-need-help-urgently/#findComment-7298130
Make sure both your 24pin power and 8pin power are connected to the motherboard.
That's actually a 4pin on the bazooka, it's by the CPU socket.
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/553539-need-help-urgently/#findComment-7298131
