If you are running the 950 pro on an NVME controller (using PCIE) it will perform faster. Will it be noticeable...maybe...depends on the read/write tasks you are performing....general wisdom I have seen is that NVME over PCIE is indeed faster but the cost difference many not be worth it for the average user or gamer.
浪速の建てるは静か用に建てました!- Build Log Coming Soon!
https://linustechtips.com/topic/553365-samsung-950-pro/#findComment-7296531
