16 minutes ago, TravisB said:
Does anyone know any people I can send my PC case panel to get a square cut out for a window and is in new Zealand?
Try and contact some pc modders or you could even try a panel beaters. All you really need is an angle grinder or dremel and steady hands. Measure, tape up then grind away.
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
https://linustechtips.com/topic/552767-pc-case-window-cutters/#findComment-7290085
1 minute ago, TravisB said:
Alright, Know of any PC modders in New Zealand?
Nope. Go through the build logs section and you might find some or even try youtube and google. I know there's a guy that did or does custom pc desks in nz.
https://linustechtips.com/topic/552767-pc-case-window-cutters/#findComment-7290099
If you search for a local workshop that has a bandsaw/jigsaw workstation you could technically by the materials yourself & use an existing workshop facility or ask for it to be cut by the company & get it shipped back to oneself.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/552767-pc-case-window-cutters/#findComment-7290135
