Part list: http://pcpartpicker.com/p/BsLjf7
Long story short, me and a buddy built his first PC and used a USB to install an activated copy of Windows 7 on his SSD. After we installed it we tried booting into Windows and get a BSOD that says his BIOS isn't ACPI compliant. We were thinking that we need to install the CD that came with the motherboard that says "drivers & utilities" on it but booting into that CD just boots into Windows and gives us the BSOD mentioned previously.
halp.
https://linustechtips.com/topic/551882-please-help/
Have you tried clearing the CMOS? Turn off your computer unplug it. Hit the power button a few times to clear any residual power. Open your case and remove the battery on your motherboard for a few minutes. Replace the battery, plug the computer in and power on the computer. That is the only thing I can think of trying. If that doesn't work, post this in the troubleshooting forum and see if they can help.
It's always a good day if you woke up breathing.
https://linustechtips.com/topic/551882-please-help/#findComment-7282219
