====Posted in Troubleshooting also====
====Sorry, still trying to figure out this forum====
Hey,
My name is Blake. Currently the company I am working for is wanting to move from XenServer to VMware. I have it set up currently in a lab environment to try to make sure exporting from XenServer and importing to VMware is going to work the way I want it too since we are doing the move on Easter weekend. I was able to connect to VSphere just fine the other day and now I'm getting an error stating it's not able to connect do to a timeout issue. I have rebooted both the server and laptop I am working with and they are on the management VLAN I created.
Anyone know any thing to fix this? I could also just fresh install the ESXi install.
https://linustechtips.com/topic/551147-esxi-issues/
Hook up a monitor and keyboard (or use the remote management port if available) and see what the screen says. If you're able to login to the console then you should be able to do some basic troubleshooting or at least see any errors when it boots up.
-KuJoe
https://linustechtips.com/topic/551147-esxi-issues/#findComment-7273964
