So I've been reading up on loading balancing with PfSense by combining two DSL lines and it's pretty interesting. The only thing I'm having trouble understanding is that someone told me that it won't help with single streams like buffering a video, playing games, etc. Is this true?
https://linustechtips.com/topic/550665-pfsense-load-balancing/
Well with load balancing you're balancing connections between lines. So if you have a lot of connections to the outside then it could help by spreading the load. But if it's one person in an apartment playing a game, the connection will only use the one DSL line.
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
https://linustechtips.com/topic/550665-pfsense-load-balancing/#findComment-7269259
Interesting. Say there's an incoming DDoS attack. Will it take more bandwidth on their end to saturate all of the lines to make me go offline?
https://linustechtips.com/topic/550665-pfsense-load-balancing/#findComment-7269267
Well that would be going after your outside IP, which would be the modem so it would only hit one of the DSL lines.
Are you often the recipient of DoS attacks?
https://linustechtips.com/topic/550665-pfsense-load-balancing/#findComment-7269300
For home users, it will help if you sort your connection depending on usage. Example is assigning outgoing connections (TF2, CS:GO, etc) to go to WAN1 only and the rest of traffic (HTTP, SSL, etc) to WAN2. That will make your game latency to be lower since if you ever want to download or stream videos it will only use up bandwidth on WAN2 and not use bandwidth on WAN1 where your game connections are happening. You can use your imagination on what you can do with it.
https://linustechtips.com/topic/550665-pfsense-load-balancing/#findComment-7269357
So basically if one of the modems goes offline, will it also act as a failover and keep me online with the other one?
https://linustechtips.com/topic/550665-pfsense-load-balancing/#findComment-7269396
In any failover I've ever seen, you get an interruption of service, the connection is lost may have to log back in. The point of the failover is to maintain connectivity, not the individual connections.
My guess is this is not going to do what you want it to do.
https://linustechtips.com/topic/550665-pfsense-load-balancing/#findComment-7270156
