What is Wrong with my PC?!?!?!?!
Solved by NeoFrux,
Looks like you're dropping frames. There's a long story as to what exactly makes up what you're seeing here, but basically, your GPU isn't decoding the frames fast enough and is dropping them from time to time to keep up without skipping. If you're using Google Chrome, try disabling hardware acceleration, and if you use Flash on YouTube, right-click the video and go to settings, and disable hardware acceleration there, too. Dropping back to software decoding/rendering will impose a CPU hit, but it's probably going to be more reliable until you get a dGPU going. You should also check your temperatures to make sure you're not overheating.
