Desktop for work
Go to solution Solved by DrDray,
1 hour ago, cferns1 said:
I've got this:
http://uk.pcpartpicker.com/p/6xFh4D
I replaced the SSD with a 2tb HDD because 2 1tb HDD's were £80 and this drive is £56
Yeah good idea. If you did go with that build first upgrade would be an ssd then graphics card :) Good luck
Hi! So I am planning on building a system for my school work later on in the year. Here is some basic info:
1, I live in the UK
2. I have a working monitor and also fairly decent keyboard and mouse, so that isn't an issue, neither is windows as I just picked up a Windows 10 DVD.
3. I only have 1 monitor at the moment, so multi monitor compatibility would be nice, but not needed at the moment
4. My budget is around £400-£500
5. I need the system to be future proof (I'm possibly going to add a graphics card later on for some light games and for it to last a fair amount of time)
6. I am upgrading because at the moment I have all of my games and suchlike on my laptop, so I need some place to put all of that because I want to take my laptop into school
Here is some ideas for the build:
http://uk.pcpartpicker.com/p/RNyVjX
http://uk.pcpartpicker.com/p/6dj7f7
http://uk.pcpartpicker.com/p/fkhB8d
If you could help that would be great!!
Future build:
http://uk.pcpartpicker.com/p/kGgNJx
Current build: (laptop)
Use the following style specs for your profile!
Specs:
Screeninator: Intel Graphics 5500
Stickaminator: Hyandai 12GB DDR3 RAM (1x8GB, 1x4GB)
Procrastinator: Intel i5-5500U @ 2.2 GHz
Noisoundacreator: TURTLE BEACH PX4
Remembrerthing: WD 1TB Blue HDD
Flat-Colorful-Thing: Samsung SyncMaster 2323Y
See-A-Move-O: Tecknet M288
https://linustechtips.com/topic/549999-desktop-for-work/
1, I live in the UK
The list with the 4690 in it is a good build, maybe just look at getting a mechanical hdd for storage :)
If you have the option to get a high refresh rate monitor, do it.
Main PC CPU: i7 14700k CPU Cooler: NZXT x62 280mm Motherboard: Gigabyte Aorus Elite X WiFi 7 GPU: Asus Strix 3080ti RAM: Gskill Trident Z5 32gb DDR5 SSD: 990 Pro 2TB, 980 Pro 1TB Case: NZXT S340 Black PSU: Corsair RM1000e ATX3.0
Server: CPU: i7 9700k RAM: Corsair 32gb DDR4 HDD: 36tb Usable SSD: Samsung 500gb NVME Case: Fractal Define R5 PSU: Corsair RM1000e ATX3.0
https://linustechtips.com/topic/549999-desktop-for-work/#findComment-7261742
Also it would be a very capable system with a graphics card in the future
https://linustechtips.com/topic/549999-desktop-for-work/#findComment-7261761
I've got this:
Future build:
Specs:
https://linustechtips.com/topic/549999-desktop-for-work/#findComment-7261785
I've got this:
https://linustechtips.com/topic/549999-desktop-for-work/#findComment-7262267
