Hi,
So, I've recently bought a new PC which contains AMD A10 X4 7870K CPU so I have integrated graphics card. I can see on CPU-Z and AMD OverDrive that my GPU is running on less than half core speed(currently on 354.55 MHz), it should run on or around 866 MHz right?
I tried to run some games, but clock speed was still on the same level.
Another thing, I have 8 gb of ram, BIOS is showing only 4 gb. Windows shows: "installed memory: 8 gb (3.46 gb usable)."
My configuration:
Motherboard: MSI A68HM-P33 V2
Processor: AMD A10 X4 7870K (3.9GHz)
Memory: 8 GB DDR3 1600 MHz
Graphics card: AMD Radeon R7
Power Supply: REAL POWER 500W
Help needed :D
https://linustechtips.com/topic/548349-graphics-clock-speed/
Just now, TecH|ph said:
Hi,
My configuration:
Help needed :D
well is it idle?
do you have 32 bit windows?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/548349-graphics-clock-speed/#findComment-7243983
6 minutes ago, TecH|ph said:
Hi,
My configuration:
Help needed :D
The ram issue is due to you using a 32-bit OS
The integrated graphics isnt entirely the best thing to use, a onboard graphics will use some of the CPU processing power, as the graphics are built into the cpu for amd cpus
https://linustechtips.com/topic/548349-graphics-clock-speed/#findComment-7244065
I'm using 64-bit OS*
So there's nothing to do with this?
https://linustechtips.com/topic/548349-graphics-clock-speed/#findComment-7244174
