Hello guys :)
I dont know where to put this topic im new to site,im planing to build myself a buget gaming PC for 450$ dolars.
On that pc im planing to play high demaning games like Witcher 3,Dragon age 3,battlefield 4 and Fallout 4.
Heres pc part list:
CPU:INTEL pentium G4400
MBO: GA-H110M-DS2 https://www.links.hr/hr/maticna-ploca-gigabyte-ga-h110m-ds2-ddr3-intel-h110-ddr3-zvuk-sata-pci-e-3-0-d-sub-usb-3-0-matx-s-1151-0503061113
RAM: Corsair Vengeance Low Profile 8Gb
PSU: ANTEC VP500PC ES 500W
GPU:Im open to sugestions im looking for price/performance ratio cards :D
I dont wanna buy a case and DVD drive becouse i have them ,I wanna buy this parts over ebay or amazon so if theres are any of you  that buyed parts over internet i would like to know if parts came in one peace and if they worked. :)
Thanks in advance and best regards.
https://linustechtips.com/topic/548321-building-buget-pc-for-450/
you need a quadcore.
athlon 860k would do.
I have a rig with the Athlon 860k in it paired with an XFX R9 380 4gb and there is a very slight bottleneck non overclocked
  • CPU: AMD athlon  860k
  • Motherboard: Gigabyte F2A58M-HD2
  • RAM:2x4gb HyperX Fury
  • GPU: XFX R9 380 4gb
  • Case: NXZT S340
  • PSU: EVGA 650G
  • Display: BenQ GL2460HM
  • Cooling: Hyper 212 Evo
  • Keyboard: Corsair k60
  • Mouse: Steelseries Rival 300 (white
  • Sound Logitech g430
  • Operating System: Windows 10 64bit
5 minutes ago, Zoran98 said:
Hello guys :)
Heres pc part list:
Yea also i would like to have a PC that i could upgrade in future.
then your best bet would be to try and squeeze in i3 6100.
11 minutes ago, Zoran98 said:
That would be a great idea,but would that cpu handle those games?
6100 handles everything
As I mentioned earlier Witcher 3 is extremely CPU intensive, a dual core cannot handle it. You definitely need a quad core. You can find more about that here >>>>>>>>>>>>>>>>> http://www.pcworld.com/article/2866538/the-witcher-3s-system-requirements-are-steep-but-surprisingly-reasonable.html
You should probably go for i5 4460 if you want an Intel CPU.
I am not an AMD guy. Hence, I can't suggest anything regarding AMD CPUs.
6100 runs witcher 3 easily since it's 4 threaded.
hey what do you think about this :)
**CPU** | [Intel Core i3-6100 3.7GHz Dual-Core Processor](http://pcpartpicker.com/part/intel-cpu-bx80662i36100) | $124.69 @ OutletPC
**Motherboard** | [ASRock B150M Pro4 Micro ATX LGA1151 Motherboard](http://pcpartpicker.com/part/asrock-motherboard-b150mpro4) | $83.99 @ Newegg
**Memory** | [G.Skill NT Series 8GB (2 x 4GB) DDR4-2133 Memory](http://pcpartpicker.com/part/gskill-memory-f42133c15d8gnt) | $38.99 @ Newegg
**Video Card** | [Gigabyte GeForce GTX 960 4GB Video Card](http://pcpartpicker.com/part/gigabyte-video-card-gvn960wf2oc4gd) | $189.99 @ Newegg
**Case** | [Enermax Thorex ATX Mid Tower Case](http://pcpartpicker.com/part/enermax-case-eca3321bbtu2) | $19.99 @ Newegg
**Power Supply** | [EVGA 500W 80+ Bronze Certified ATX Power Supply](http://pcpartpicker.com/part/evga-power-supply-100b10500kr) | $35.98 @ Newegg
 **Total** | **$493.63**
It's fine, 380 is faster than 960
