Hello guys,
I recently buyed a new rig but i encountered a serious problem,
actual build;
i7-6700k
asus viii gene
corsair vengeance lpx (4x4 GB)
and i used some old stuff (budget limitation)
old 700w psu (80+ silver)
and 1 sapphire hd 6870
i installed everything and the pc do just fine but when i installed the gpu the mobo recognize it only if i put it in the 8x slot, not in the 16x one.
so i have the last bios update for mobo and i updated the vbios of the gpu, wednesday i hope  a friend of mine will took his video card here to test it out.
the strange things is that the card fans spins so i don't think it's the card and i was guessing there are maybe some compatibility issues with this new chipset?
or i just got a bad mobo with a faulty pcie slot?
https://linustechtips.com/topic/547761-problem-with-pcie-slot/
Which pcie slot did you use?
And do you have something else plugged into the pcie or m.2 slots?
Edited by Domifi
CPU: Ryzen 3700X VGA: RX 5700 8G RAM: 32GB 3200MT/s DDR4 Motherboard: B450 Aorus Pro
Storage: 2x1TB Crucial P2, 1TB Crucial MX500, 36TB NAS Cooling: Custom Loop 360mm & 280mm
PSU: Super Flower Golden Green HX 650W Case: Phanteks Enthoo Luxe
https://linustechtips.com/topic/547761-problem-with-pcie-slot/#findComment-7237816
2 minutes ago, neurotik said:
if i put the card on the first 1 (the nearest to the cpu) it doesn't get recognized (i look if it's recognized in the bios)
on the second one it get recognized and works but it's an 8x slot
That's because the second slot is only a 8x slot electrically. That the top slot isn't working is a concern, do you have a different GPU to test with or a different PC to test the GPU with? If not, it shouldn't be a problem anyways: Your GPU won't be bottlenecked by an PCIE Gen 3.0 8x slot.
https://linustechtips.com/topic/547761-problem-with-pcie-slot/#findComment-7237876
by any chance, with the card in the 1st PCIe do you have video output from the on-board?
if yes, go into BIOS and change 1st video to PEG
see page 3-26 of the manual: https://a248.e.akamai.net/f/1828/2290/9f/dlcdnet.asus.com/pub/ASUS/mb/LGA1151/MAXIMUS_VIII_GENE/E10484_MAXIMUS_VIII_GENE_UM_WEB.pdf
https://linustechtips.com/topic/547761-problem-with-pcie-slot/#findComment-7238081
5 minutes ago, neurotik said:
i already tryed that, i enabled dual monitor and connected both the video card and the on board gpu to two different monitor, black on the monitor connected to the gpu
well ... the issue at hand could be quite complicated since top two PCIe connectors have PCIe lanes directly from the CPU
what you could also try is to change PCIe configuration to PCIe gen 2, the HD6870 is a PCIe gen2.1 card
see manual page 3-27 top
https://linustechtips.com/topic/547761-problem-with-pcie-slot/#findComment-7238137
when i first mounted the cpu i saw a bent pin on the board, i set that in place na dinstalled the cpu and everything was working....it's maybe the problem?, also tryed pcie 2nd gen no luck....i think i need to try another video card and hope not to rma
https://linustechtips.com/topic/547761-problem-with-pcie-slot/#findComment-7238152
7 hours ago, neurotik said:
don't you think it's possible that the video card is not compatible with the new lga 1151?
the short answer, no
the long one ... no
the LGA1151 tech specs should be here: https://www-ssl.intel.com/content/www/us/en/processors/core/desktop-6th-gen-core-family-datasheet-vol-1.html
but for some reason, I can't download it; possible maintenance on Intel's domain
le: nah .. it's not there
Edited by zMeul
https://linustechtips.com/topic/547761-problem-with-pcie-slot/#findComment-7238367
hello, sorry for beign late but i maybe found somethings, i installed aida64 and when i check motherboard-chipset-pcie controller i only see 1 controller that says port #2, it maybe means that the controller on port 1 is not recognized?
edit:
when i connected the card aida shows the 2 pcie slot...
https://linustechtips.com/topic/547761-problem-with-pcie-slot/#findComment-7292796
