How are you upgrading your CPU? Just the CPU or the motherboard as well?
https://linustechtips.com/topic/547629-changing-cpu-question/#findComment-7236355
9 minutes ago, sebz2 said:
You'll need to update your drivers if your getting a new motherboard as well - no reinstall windows or anything, cause thats on your harddrive!
Not sure how to interpret part of this post. Drivers are on the boot drive as well by default. Can you elaborate your post?
https://linustechtips.com/topic/547629-changing-cpu-question/#findComment-7236359
When I upgraded my motherboard or something I got way less fps when my cpu was 3x better then my old core 2 duo. I put in the disk thing from the gigabyte MB and installed it and wallah higher fps.
https://linustechtips.com/topic/547629-changing-cpu-question/#findComment-7236366
You installed drivers from the disc, which tells me that the drivers may have had to be reinstalled. That being said, the drivers on the disc are outdated and should be grabbed from the manufacturer's website, either of the individual component or from the motherboard's product support page.
https://linustechtips.com/topic/547629-changing-cpu-question/#findComment-7236379
Oh i guess I will do that later xD thanks!
https://linustechtips.com/topic/547629-changing-cpu-question/#findComment-7236385
3 minutes ago, Nacho Marco Segui said:
You just swap the cpu, that is what i did when i changed my i3 4160 to my 4790k. It only took a little bit longer to boot
Not necessarily true. In your case, you had Haswell Refresh CPUs. If you were to go from normal Haswell to Haswell Refresh, a BIOS update might be required in order to use the CPU. Same goes with Intel's latest CPUs. A BIOS update is required in order to fully use them.
https://linustechtips.com/topic/547629-changing-cpu-question/#findComment-7236455
