So im going to upgrade my wifi and my ethernet, i only get 12Mbps up and .64Mbps down. Should i so with a Ubiquiti 600ft 300Mbps or a 400ft 450Mbps. 12Mbps is the highest i can get unless i go fiber and i have not checked how much a 1GB connection over fiber would be.
Thanks
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/54755-wi-fi-upgrade-help/
What data plan do you got? Like @ObeseWalrus said, you will probably not get higher speeds (at least not for your Internet traffic like downloads) by changing router.
If you transfer a lot of files over your LAN, then a higher end router might benefit you. If you want faster download speeds then you need to contact your ISP. Also, I don't think you can get fiber where you live, since people who do usually (at least from what I've seen) have higher speeds than 12Mbps down and 1Mbps up.
https://linustechtips.com/topic/54755-wi-fi-upgrade-help/#findComment-737134
No, i know it wont benefit download speeds but my wifi drops all the time the modems starting to go bad. Also i do have fiber here i just dont know how much it is
| F@H STATS |
https://linustechtips.com/topic/54755-wi-fi-upgrade-help/#findComment-750163
