cpu is dying
Go to solution Solved by Husky,
14 minutes ago, eklaros said:
i checked the price in germany  i7 5820k  is 400€ alone so ddr4 ram and the mainboard on top of it i might hit 600..
You can get the i5 6600K and ASUS Z170-A Motherboard:
i5 6600K: http://pcpartpicker.com/part/intel-cpu-bx80662i56600k
ASUS Z170-A: http://pcpartpicker.com/part/asus-motherboard-z170a
That would be a killer upgrade from your current system! :)
Hey its been a while last time i came here i was looking for a new cpu to replace my old t1090 x6 my budget wasn't really big and so people recommend to wait for Zen
now after a while my Pc starts to randomly frezze for a short period, and sometimes if i render videos it's just turns off and on like in the old days when it was overlock.
I wouldn't mind waiting longer but Zen seems like to take longer then expected. Time has passed my budget is now 300-400€ is there still no good Cpu upgrade that would boost my Performance ?.
I got some Ideas like xeon 1231v3 or the skylake where iwould try to scrap a bit more money for the mainboard but only if i can get like a significant performance boost.
https://linustechtips.com/topic/547520-cpu-is-dying/
PC:
AMD Ryzen 9 5900X | AMD Radeon RX 7900 GRE | 32 GB RAM | Arch Linux
Laptop:
MacBook Pro 13" (2019) | Intel Core i5 8279U | 8 GB RAM | macOS
Server:
Intel Core i7 6700K | 16 GB RAM | 2 TB HDD | Debian Linux
https://linustechtips.com/topic/547520-cpu-is-dying/#findComment-7235349
Even multi threaded as well.
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/547520-cpu-is-dying/#findComment-7235354
wow yes this looks really good i mean if the 5820k is significant better then the i5 6600k then saving money for it and waiting longer wouldnt be the problem but if you guys say it's not that big then i would buy the 6600k its not like i switch cpus every year or so .
https://linustechtips.com/topic/547520-cpu-is-dying/#findComment-7235359
Just now, eklaros said:
wow yes this looks really good i mean if the 5820k is significant better then the i5 6600k then saving money for it and waiting longer wouldnt be the problem but if you guys say it not that big then i would buy the 6600k its not like i switch cpus every year or so .
The 5820K is better in Multithreaded stuff while the 6600K is better in Singlethreaded stuff.
Personally I would go for the 6600K over the 5820K. The 5820K is not worth it in my opinion. If you get the 6600K then you're on the new Skylake platform. Apparently Windows 10 runs better on Skylake because it utilises Skylake features better.
Sorry I forgot to include DDR4 RAM, here you go this is 16GB of it :)http://pcpartpicker.com/part/gskill-memory-f42400c15d16gvr
PC:
Laptop:
Server:
https://linustechtips.com/topic/547520-cpu-is-dying/#findComment-7235374
alright i think i go with it i mean if the difference is not world's i can live with it :)
https://linustechtips.com/topic/547520-cpu-is-dying/#findComment-7235381
Just now, SXTC said:
I wouldn't go for 6600k since directx 12 works better with hypertreading, a function the 6600k doesn't support. So you'll run into a small bottleneck once more directx 12 games appear.
Yes that could be a problem i love offline rpgs and strategy games and always looking for the newest out there what would you recommend then?.
https://linustechtips.com/topic/547520-cpu-is-dying/#findComment-7235397
Remember, DirectX 12 better utilizes Hyperthreading. It doesn't mean that the 6600K is going to be "worse" than a hyperthreaded CPU.
That 6600K isn't going to bottleneck basically anything.
PC:
Laptop:
Server:
https://linustechtips.com/topic/547520-cpu-is-dying/#findComment-7235421
do you have a suggestion the next cpu with hyperthreading available you would recommend i go with the 6600k for now but just to be save.
https://linustechtips.com/topic/547520-cpu-is-dying/#findComment-7235427
1 minute ago, eklaros said:
do you have a suggestion the next cpu with hyperthreading avaible you would recommend i go with the 6600k for now but just to be save.
The i7 6700K has hyperthreading. I wouldn't worry as the 6600K will definitely last more than 3 years.
PC:
Laptop:
Server:
https://linustechtips.com/topic/547520-cpu-is-dying/#findComment-7235432
yes thats sounds good in 3 years i got the money for a new cpu :).
As I said, don't worry, it will easily last 4 years.
It will last even more if you don't need to be on the latest hardware all the time.
And you're on the Skylake platform, so if you do need to upgrade, all you need is a new CPU, plus you'll have 16GBs of RAM, which is more than enough. :)
PC:
Laptop:
Server:
https://linustechtips.com/topic/547520-cpu-is-dying/#findComment-7235449
hm do you have other suggestion for the motherboard or is it necessarily needed to overclock because i have not so much experience with overlocking
https://linustechtips.com/topic/547520-cpu-is-dying/#findComment-7235451
Any Z170 board with the features you want should work just fine. You do need a Z170 board to overclock, any other chipset will not be able to overclock. Even if you don't want to overclock though, I would still recommend going with a Z170 board just for the features.
Core i5 6600k | Gigabyte GTX 970 Windforce | MSI Z170 Krait Gaming Crucial Ballistix Sport 16GB DDR4 2400 | NZXT S340 Red                                              EVGA SuperNOVA 750 G2 | Coolermaster Hyper 212 Evo | Razer Blackwidow Tournament | Logitech G600 Razer Kraken USB        If you want me to see your post, please remember to quote me!
https://linustechtips.com/topic/547520-cpu-is-dying/#findComment-7235470
If you don't want to overclock, the instead of a 6600K, get the 6600 (without the K). If you do want to overclock, then get the 6600K
I would choose that board to overclock since it's quality and the ASUS UEFI is pretty neat and easy to use.
PC:
Laptop:
Server:
https://linustechtips.com/topic/547520-cpu-is-dying/#findComment-7235473
alright its set now thank you for helping me :) .
https://linustechtips.com/topic/547520-cpu-is-dying/#findComment-7235488
No Problem! :)
Good luck upgrading! Hope you enjoy your new system! :)
PC:
Laptop:
Server:
https://linustechtips.com/topic/547520-cpu-is-dying/#findComment-7235497
