HELP ! IT KEEP SHOCKING ME !
By
o0odellero0o
in Power Supplies
in Power Supplies
Solved by W-L,
30 minutes ago, o0odellero0o said:diy cardboard case and foam under motherboard.
Make sure your outlet is grounded or things can potentially build up charges that can potentially be dangerous, but if your on carpet or were just statically charge that could also be a result of the shock.
YoungBlade ·
Posted in CPUs, Motherboards, and Memory7 -
1
derekchan ·
Posted in New Builds and Planning7 -
5
4
6
kerriya ·
Posted in Cases and Mods9
play_circle_filled
Latest From ShortCircuit:
