I'm ordering parts of my PC tomorrow and I want to know the ABSOLUTE best bang for my buck PC I can find. I have a budget of 1180 (base price, no retail) and I can go as far as 1220-1230. Please include an Asus VG248QE in there. HELP ME PLEASE!!!! (first build btw) only going to be single monitor gaming, CS:go and others
https://linustechtips.com/topic/546794-help-fast/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.89 @ OutletPC)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($61.98 @ Newegg)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1866 Memory  ($40.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($84.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: PowerColor Radeon R9 390 8GB Video Card  ($279.99 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($64.99 @ Micro Center)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($64.99 @ Amazon)
Monitor: Asus VG248QE 144Hz 24.0" Monitor  ($249.00 @ Amazon)
Total: $1071.61
Generated by PCPartPicker 2016-02-12 23:46 EST-0500
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/546794-help-fast/#findComment-7228481
Start with PCPartPicker.com
ROG X570-F Strix AMD R9 5900X | EK Elite 360 | EVGA 3080 FTW3 Ultra | G.Skill Trident Z Neo 64gb | Samsung 980 PRO
ROG Strix XG349C Corsair 4000 | Bose C5 | ROG Swift PG279Q
Logitech G810 Orion Sennheiser HD 518 |  Logitech 502 Hero
https://linustechtips.com/topic/546794-help-fast/#findComment-7228482
Total: $1071.61
Would you go with the 4460 or 6500?
https://linustechtips.com/topic/546794-help-fast/#findComment-7228485
I guess the 6500 would be better if you can afford it.
The difference, IMO, is minimal but it'd be nice to have a Skylake build.
https://linustechtips.com/topic/546794-help-fast/#findComment-7228498
1 minute ago, XVII said:
I can go for more than that.. let's say 1220 was my budget. I don't want it to be super super budgety
If you do go for the 6500 make sure you upgrade the ram to ddr4 or else it won't work. Also get a motherboard with a LGA1151 socket.
https://linustechtips.com/topic/546794-help-fast/#findComment-7228525
Then I guess this would work:
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($244.99 @ NCIX US)
CPU Cooler: be quiet! PURE ROCK 51.4 CFM Sleeve Bearing CPU Cooler  ($32.99 @ NCIX US)
Motherboard: Gigabyte GA-Z170-HD3 ATX LGA1151 Motherboard  ($104.99 @ Amazon)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory  ($43.00 @ Amazon)
Total: $1219.72
Generated by PCPartPicker 2016-02-12 23:54 EST-0500
https://linustechtips.com/topic/546794-help-fast/#findComment-7228526
Total: $1219.72
That looks amazing, I was able to change to the 970 because the higher base clock and such.. get dual channel because it was a 1.90 dollar difference, and downgraded to a 120gb ssd for windows and one game.. Thank you. and would the cryorig h7 be better than that cooler? or is that really good. but I appreciate it a lot..
P.S: What would be a good overclock setting? is it possible to do 4.5 ish on 1.25 volts? or 1.2 volts? do you think it's possible
https://linustechtips.com/topic/546794-help-fast/#findComment-7228567
The PURE ROCK and H7 are identical. I simply chose the PURE ROCK because it matches the motherboard aesthetically better. Either would work.
I'd push the 6600K to about 1.35V if it's possible. Unlikely to get 4.5Ghz on 1.25V unless you've won the silicon lottery.
https://linustechtips.com/topic/546794-help-fast/#findComment-7228586
I heard it's bad to get over 1.25 on an AIR cooler, what is a good voltage for around 4.5 ghz in your opinion?
https://linustechtips.com/topic/546794-help-fast/#findComment-7228606
Nah, I'd probably push it 1.3V first and look at the temps, and go from there. Like I said, depends on the silicon lottery.
https://linustechtips.com/topic/546794-help-fast/#findComment-7228615
what's a good temp for your cpu to be at?
80C on load would be my limit. Anything below that would be fine in my book.
https://linustechtips.com/topic/546794-help-fast/#findComment-7228666
Go for a dual channel 2x4GB memory kit. The difference between dual and single channel is quite small, but on a new system it makes sense to me to maximize performance for the $ spent. G.Skill NT Series 8GB (2 x 4GB) DDR4-2400 Memory  or Kingston FURY 8GB (2 x 4GB) DDR4-2400 Memory would be decent choices.
https://linustechtips.com/topic/546794-help-fast/#findComment-7228805
