Bought a bunch of random crap and pieced a full system together. Didn't wonna get a lot of fancy stuff for my first build and change stuff down the road. Some stuff didn't fit as I didn't plan well. Crappy phone pics.
Gonna get a ddc or d5 ek pump. This thermaltake pump is pretty loud, not sure if that's because of the resistance or routing or cheap. Would also like somewhere to control the fans based off gpu temps like my h100i an corsair software allowed me too.
https://linustechtips.com/topic/546744-first-custom-loop-build/
Just now, Josephdalepi said:
is that an asus motherboard?
Of course.
https://linustechtips.com/topic/546744-first-custom-loop-build/#findComment-7228076
asus bios or fan xpert
damn good choice of motherboard
Well there aren't any sensors for the gpu temp, so it doesn't do much there. Ill get fan xpert and see.
https://linustechtips.com/topic/546744-first-custom-loop-build/#findComment-7228088
if your board supports it
but what do you mean no sensor for cpu temp?
what the fuck?
gpu, I want the fans to correlate to gpu temp.
https://linustechtips.com/topic/546744-first-custom-loop-build/#findComment-7228099
ohhhh
i dont think you can do that one
if you can, though, asus would be the one to let you
Like I said, while using my h100i, I could with their software. I would just need some sort of usb/fan hub device and still use their software. Asus suite 2 doesn't come closing to seeing anything gpu related.
https://linustechtips.com/topic/546744-first-custom-loop-build/#findComment-7228117
hardware fan controller with temp probes would work
also, about speedfan
your using a sabertooth, so make sure to save everything before opening it the first time
it crashed my computer and is known to do that with some asus boards
https://linustechtips.com/topic/546744-first-custom-loop-build/#findComment-7228124
