Hey guys, my website specialist/hoster went missing and I need my website to go online immediately as it is from a restaurant. It works on this site s429739212.online.de but I cant get it to work on the regular domain that I bought, www.rhoendorferhof.de
it says that there is no content available-error 403 but on google, it shows the site with the description and everything. It just doesn't work if you click on it. Please help!!!
Thanks in advance!
https://linustechtips.com/topic/546547-continued-problem-with-website/
Hi, do you have access to your domains DNS?
If you do you can add an A record with a host of '@' and the points to as 's429739212.online.de'
The vocabulary your hosting company uses for the a record may differ but the host is usually the first box and the point to is usually second. Here is an example image of an a record from godaddy (not my image).
