hi,
am useing a msi 970 gaming mobo, win 10 OS.
last day my OS crashed (after start up its stuck) so i reset the win 10, after that there is no audio, its says "No audio output device is installed" is it a mobo problem?? or am i missing something??
( i installed the sound blaster  cinema 2 and realtech hd audio)
plzz help
https://linustechtips.com/topic/546328-msi-970-gaming-mobo-problem/
2 minutes ago, Alexokan said:
I had to install driver for internet before it would work, but I have not had these issues.
You might want to try a bios flash if you continue to have problems.
i have installed all the latest driver but still the same problem,
in device manager there is a caution sign in "HD audio bus" its showing code 39 driver missing or corrupted
