Hello Guys!
I have a question if someone could answer it to me.
Where I live we are starting to get electricity regulatios as well as  blackouts very frecuently (once a week) . I have my precious pc conected directly to the wall and is usually fine since it's turned off when I'm not at home and if there is a blackout i just disconect it until 10 mins after the energy is back on(I Have had 5 blackouts in 5 years living here 2 of wich where this week. The goverment anounced it will be frecuent from now on) . With all this problems comming ahead I was wondering if it might be a good Idea to get a UPS or if I'll be fine with a Voltage Regulator(shield). Since the ups a pretty expensive here and it's not somenthing I could really afford  uless it is completly necesary .
Sorry for bad  English/Spelling.
https://linustechtips.com/topic/546082-do-i-need-an-ups/
1 minute ago, Hyundidontknow said:
Hello Guys!
If you dont have the system on, you should be fine with a surge protector, but if you are going to be powered on, it is better to use a ups.
https://linustechtips.com/topic/546082-do-i-need-an-ups/#findComment-7221000
