Switch power supply
11 minutes ago, EmeraldFlame said:Just grab a cheap power brick, if you can't find a 7.5V 1A one, you can grab a universal on like this: http://www.amazon.com/ZOZO-Universal-Regulated-Replacement-Electronic/dp/B015PXUHYA/ref=sr_1_4?ie=UTF8&qid=1455202124&sr=8-4&keywords=universal+ac+adapter
Amazon shipping takes at least 2 weeks and I'm better off just making an in-line voltage regulator on my 12V supply
Since writing this I talked to my dad about it and he pointed me to the LM7808 IC that, paired with a couple of caps and a heatsink (so I don't fry the IC), will step the voltage down to 8V which will be just fine.
The LM7808 is like $0.25 and I have the caps I need already, and a variety of heatsinks I can chose from. Shouldn't take more than 5 minutes to set everything up
