I want these parts. Might use a FTW gpu instead of a Hybrid. I don't want to buy a 250 dollar motherboard.  Why doesn't it like this (still way expensive) one?
PCPartPicker part list: http://pcpartpicker.com/p/6Bbjf7
Price breakdown by merchant: http://pcpartpicker.com/p/6Bbjf7/by_merchant/
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($374.99 @ Newegg)
CPU Cooler: Noctua NH-D14 SE2011 CPU Cooler  ($85.39 @ Amazon)
Motherboard: EVGA Z170 FTW ATX LGA1151 Motherboard  ($189.99 @ Amazon)
Storage: Samsung 850 EVO 500GB M.2-2280 Solid State Drive  ($152.99 @ Micro Center)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($65.99 @ SuperBiiz)
Video Card: EVGA GeForce GTX 980 Ti 6GB HYBRID Video Card  ($689.99 @ Amazon)
Case: Phanteks Enthoo Mini XL MicroATX Desktop Case  ($169.99 @ Newegg)
Total: $1729.33
Generated by PCPartPicker 2016-02-10 11:33 EST-0500
https://linustechtips.com/topic/545140-first-build-compatability-help/
Are you gonna overclock?
Current Build: Core i7 4790k @ 4.6, Asus Maximus VII Hero, Corsair Vengeance Pro 2400mhz 8gb (2x4gb), GTX 980ti, NZXT Kraken X61, Fractal Define R5  EVGA Supernova B2 850w, Some 300gb hard drive.
http://pcpartpicker.com/p/W7CNrH
because of the Micro ATX case
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
Total: $1729.33
click on details. you have a x99 cpu but a skylake mbo and the mbo doesn't support your cpu cooler AND you choose a micro-ATx case but a ATX mbo.
Yup you need to decide on whether you want X99 or z170, then you need to decide what form factor(size) build you're going for.
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
What he said.
Also, RAM?
LTT Unigine SUPERPOSITION scoreboardhttps://docs.google.com/spreadsheets/d/1jvq_--P35FbqY8Iv_jn3YZ_7iP1I_hR0_vk7DjKsZgI/edit#gid=0
Intel i7 8700k || ASUS Z370-I ITX || AMD Radeon VII || 16GB 4266mhz DDR4 || Silverstone 800W SFX-L || 512GB 950 PRO M.2 + 3.5TB of storage SSD's
SCHIIT Lyr 3 Multibit || HiFiMAN HE-1000 V2 || MrSpeakers Ether C
1 minute ago, Duchess said:
Gaming. I picked the cpu because the game I'm going to play (when it comes out) will use the extra cores
Buying x99 just for gaming isn't really smart. Better go skylake i5-6600k and a 980ti or 390 depending on the resolution you play on.
Is that why only like 5 motherboards come up when I search?
I'm not sure what your searching for but both the X99 and z170 have a bunch of motherboards available(at least in ATX form factor) you might be limited to a small number if you are looking at small form factor options.
Just now, Duchess said:
Haven't picked it yet. Probably corsair because all the others look like fucking beyblades
http://pcpartpicker.com/p/FnLDD3
The case is really expensive, I would recommend something else, the hybrid card really isn't going to serve you any benifit
He did, but still, 5 is enough options in my mind.
So the cpu requires that motherboard?
Cpu requires X99 mbo, Case requires mini-ATX.
But again, for just gaming you don't need that many cores, x99 is for edditing/rendering and CAD modeling.
MBO short for motherboard?
But don't I need a micro or normal atx?  Not mini?
pcpartpicker says it's compatible, you can probably get it cheaper somewhere else.
http://pcpartpicker.com/p/rDZ8Lk
