Hello! I'm new to this forum and I've watched LinusTechTips a bunch of times and I decided to ascend into the pcmasterrace. I have an idea of what my build is going to be, and I have a budget of around 1220. can't go over it (final base price, without rebates) and I want to play on ONE 1080p 144hz monitor, preferably an Asus VG248QE. I don't care for color scheme, I would like it to be white or something light. I have an idea, and I wanted to know if it was good or not.
CPU: AMD FX-8350 4.0GHz 8-Core Processor  ($164.99 @ SuperBiiz)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($114.99 @ B&H)
Motherboard: MSI 970A SLI Krait Edition ATX AM3+ Motherboard  ($86.99 @ NCIX US)
Memory: Kingston HyperX Fury White 8GB (2 x 4GB) DDR3-1866 Memory  ($41.92 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($46.89 @ OutletPC)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($324.99 @ B&H)
Case: Fractal Design Define S ATX Mid Tower Case  ($79.99 @ NCIX US)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ NCIX US)
Monitor: Asus VG248QE 144Hz 24.0" Monitor  ($249.00 @ Amazon)
Total: $1169.75
Generated by PCPartPicker 2016-02-09 23:58 EST-0500
I'll be looking forward to your guys' help :) (btw I know r9 390 is better, but I don't think I'll be playing 1440p any time soon)
https://linustechtips.com/topic/544895-first-build-help/
the thing I would add is an SSD (preferably like a 240 GB so you can put your OS and a few programs on there) , it will make the computer feel SO much faster launching stuff, I know from changing out from a mechanical HDD to an SSD, my computer feels lightyears faster.
this is what I got, but pretty much any SSD from a reputable brand like kingston, samsung, crucial, adata, etc should be okay.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211984
https://linustechtips.com/topic/544895-first-build-help/#findComment-7207302
I got you, should I replace the HD with the SSD and get the HD as like an upgrade?
https://linustechtips.com/topic/544895-first-build-help/#findComment-7207316
depends on if your budget can support it, I personally think it would be nice to have both at once, because after downloading a few games onto an SSD, it can eat up space quickly so having the extra space of a mechanical HDD is nice, but the nice thing is adding an HDD is a pretty simple upgrade.
https://linustechtips.com/topic/544895-first-build-help/#findComment-7207345
Total: $1169.75
I wouldn't recommend the HDD. Try a Western Digital Blue 1tb. I heard that it wasn't very reliable :/.
Research it though...
https://linustechtips.com/topic/544895-first-build-help/#findComment-7207384
23 minutes ago, XVII said:
Can you build me an intel based build?
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($249.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.44 @ Amazon)
Motherboard: MSI Z170A KRAIT GAMING ATX LGA1151 Motherboard  ($141.46 @ SuperBiiz)
Memory: G.Skill NT Series 8GB (2 x 4GB) DDR4-2400 Memory  ($39.99 @ Newegg)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive  ($64.99 @ Amazon)
Video Card: Gigabyte Radeon R9 390 8GB Video Card  ($299.99 @ SuperBiiz)
Case: NZXT S340 (White) ATX Mid Tower Case  ($64.99 @ Micro Center)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($64.99 @ Amazon)
Total: $1204.84
Generated by PCPartPicker 2016-02-10 00:48 EST-0500
https://linustechtips.com/topic/544895-first-build-help/#findComment-7207471
