So I'm building a new rig relatively soon and want to put it into a custom scratch case i will build. I'm planning to use wood but i don't know what type and whether to go 1/2" or 3/4" for strength. Also recommendations for something like front io would help, keep in mind i have an old $50 case im gonna probably chop up to get motherboard tray. and i can use fan grills and drive bays etc. etc. from
https://linustechtips.com/topic/544827-scratch-case-build/
I am not educated in this topic, but I've heard plywood? I think 1/2" should be enough given it's strong wood
Intel i7 6700K | MSI Krait Z170A MSI GTX 980 w/ NZXT Kraken G10/x31 Corsair Vengeance LPX 16GB Samsung 850 EVO 500GB SSD/WD Blue 1TB HDD NZXT H440 | K70 RGB/SteelSeries Rival
https://linustechtips.com/topic/544827-scratch-case-build/#findComment-7206437
Half inch should be plenty thick. The hard part is the fans. Drilling the holes for the fans  while  writing this i realized that you can just drill a large hole rather than perforation and cover it with a fan grill.
If I use words like probably or most likely, it is because I dislike certainty. These words can probably be omitted and the sentence read as a certainty.
https://linustechtips.com/topic/544827-scratch-case-build/#findComment-7206479
yeah drilling is not the hard part my dad used to work in construction and has like more tools than i should ever need
https://linustechtips.com/topic/544827-scratch-case-build/#findComment-7206487
That is always amazing when tools aren't a problem.
https://linustechtips.com/topic/544827-scratch-case-build/#findComment-7206496
yeah when i was looking at costs im like oh my god the tools will be so expensive and i asked my dad what he had and he listed off like so many things so i took a little breather and revived my wallets survival hopes
https://linustechtips.com/topic/544827-scratch-case-build/#findComment-7206510
Good luck and keep the forum updated on progress please.
https://linustechtips.com/topic/544827-scratch-case-build/#findComment-7206516
