Hi,
I'm after a case that would go well with the reference GTX 980 Ti with green LED's
I have the ASUS Maximus VIII Formula which will be RGB Lighting to green
I will have a H110i GTX cpu all in one watercooler.
Help me find a case that'll fit well with the colour scheme.
Cheers!
https://linustechtips.com/topic/544787-case-help-designer-build/
5 minutes ago, Mynx said:
Hi,
Cheers!
seeing that razer puts there green stuf in a black case, I would just go for any black case with led's.
personal favorite: coolermaster mastercase pro 5
https://linustechtips.com/topic/544787-case-help-designer-build/#findComment-7206045
