Silent Optical Drive
Go to solution Solved by Dabombinable,
3 minutes ago, Yames said:
Does higher "x" mean higher speeds or something? I can wait as long as I need to, I just need silence.
Yep. And most new ODD do not have the vibration dampening found in older ODD (1998 Diamondmax 24x CD drive, 2x rubber vibration dampeners on each side inside the ODD itself, same with my 2004 Pioneer ODD).
If you want quiet ODD then I think you'll need to go with older ones. My current Poiner x16 IDE drive (2004) is still extremely quiet as far as ODD go and is no where near as bad as my Ti 20X SATA DVD drive
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/544703-silent-optical-drive/#findComment-7205020
https://linustechtips.com/topic/544703-silent-optical-drive/#findComment-7205034
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/544703-silent-optical-drive/#findComment-7205063
1 minute ago, Yames said:
Very interesting, thank you.
BTW, this might help you find models of ODD that are quiet: http://www.quietpc.com/optical-drives
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/544703-silent-optical-drive/#findComment-7205079
