2 Graphics Cards Eyefinity + 4th Display
I recently bought a Sapphire 7970 OC 3GB to use eyefinity with. I also plan on using a 4th display to use just as a normal internet browsing station. eyefinity isn't ideal to use "normally" because it will stretch your windows across all 3 screens. So my plan is to use my 7970 with a DVI<HDMI, HDMI, and DP<HDMI setup for eyefinity, while using a very old nVidia 6000 series card with a DVI connection to run my 4th display. The reason i cant run all 4 on the 7970 is because i ran out of internal clocks unless i want to spend money on a DP splitter, which is out of the question if i am able to just use this old card to run my 4th display. So, will it work?
https://linustechtips.com/topic/54453-2-graphics-cards-eyefinity-4th-display/
i dont think you can do that
He is the hero this forum deserves but not the one it needs right now.So we'll hunt him because he can take it because he is not our hero he is a silent guardian
a watchful protector A Dark Knight
First answer i looked in Google tells that you can use 7970 for 4 monitors. No need for the other GPU. Quote from the link:
I have 3 monitors i use for eyefinity and a 32" lcdtv plugged in like this:
DVI->Monitor 3
HDMI ->TV
DP-Active DVI Adapter -> Monitor 2
DP-Active DVI Adapter -> Monitor 1
and i can use them all at once.
Source: http://www.overclock.net/t/1271535/4-monitors-on-hd-7970/10
EDIT: Didn't read the last line. If you don't want to spend money on the splitter try the thing you've planned. If you have the slots i don't think it would have problems working if you configure it properly.
I know it can run 4 monitors, but that's if the card has 2 DisplayPorts. My 7970 has
1x HDMI
1x DVI-D
1x DVI-I
1x DisplayPort
If i wanted to run four from my card, i would only be able to use a combination of 2 of the HDMI/DVI ports. So without a DisplayPort splitter, my card is limited to only 3 displays.
I installed my nVidia card into my system and was able to run a monitor off of it while running 2 off of the 7970 at the same time. I do not yet have the DP<HDMI adapter yet so i'm not sure if enabling eyefinity will cause this to stop working.
It shouldn't break if you enable Eyefinity. If it does , there is no damage done. It's kinda uncool , just checked the price of the splitter. 80$ for that. If the 2nd GPU thing doesn't work (which i doubt it) you can save up for the splitter if you think it's worth it.
