GPU Problems
Go to solution Solved by Calidus,
First thing that springs to mind is possible damage depending how your PSU died. (I've had one kill a GPU and Motherboard before)
However, I suggest trying other PCIe slots if you have any spare and to also try different outputs from your GPU, so if your using DisplayPort, try the DVI port or whichever applies to you.
The only other test would be to try in another PC if at all possible, if you still have warranty and nothing works it may be best to send it off.
I can't think of anything else which would help at this moment, but let us know how it goes.
So my PSU died recently 3: As some of you may know. However, my GPU does not seem to post. My iGPU Works fine 3: But I cant get it to take drivers from Geforce Experience and it doesnt even show the first bios screen thing. It never displays a signal. 3: Is there a way to check if it died? Yes, its seated correctly/powered correctly since I have removed and placed it back in a few times already since experiencing this. The fans do spin.  Pls halp
Moist
https://linustechtips.com/topic/544122-gpu-problems/
Wraith/Main Rig: AMD Ryzen 7 5800X3D | DeepCool AK620 | ASRock X570 Steel Legend | Micron Workstation ECC 64GB | XFX Speedster SWFT 319 Radeon RX 6800 XT 16GB | Topping D50s+A50s+PA3s | Seagate FireCuda 520 NVMe 500GB, Samsung 860 EVO M.2 1TB, Samsung 970 EVO Plus NVMe 2TB, HPE SSD 1.92TB, Toshiba X300 4TB, Seagate SkyHawk 4TB, WD Blue 4TB, HPE HDD 8TB | LG GGW-H20L Bluray-RW, Pioneer DVR-220LBK DVD-RW | HP NC550SFP 10GbE | Super Flower Leadex II Gold 750W | CoolerMaster MasterCase MC500P - Ghost/Test Rig: AMD Ryzen 7 1800X | Scythe Mugen 5 Rev.B | Asus ROG Strix X370-F | Crucial Ballistix Red 16GB | ASRock Intel ARC A770 Phantom Gaming D 8GB | Asus Xonar D2X | Crucial MX500 250GB, Seagate BarraCuda 500GB | SAMA Forza 750W Gold | Antec GX200
Phantom/Win98 Rig: AMD Athlon XP-M 2500+ | Arctic Cooling Copper Silent 3 | ASRock K7S41GX | Elixir 512MB | ATI Radeon 9800 XT 256MB with ATI Silencer 3 Rev.2 | Aureal BA88DL30A-01 Vortex 2 | Seagate Barracuda 160GB | LiteOn IHDP118-18 DVD-Rom | Samsung FDD | Ccivo 300W | CiT S008B - Parvati IV/Home Unraid Rig: Dual AMD Opteron 4184 | 2x Noctua NH-U12DO A3 | Supermicro Aplus H8DCL-i | Samsung ECC 32GB | Matrox G200eW 16MB | Kioxia Exceria G2 1TB, HPE Seagate Exos 4TB, 2x Seagate Barracuda Green 2TB, 2x Toshiba E300 2TB, Seagate SkyHawk 2TB, 2x Samsung Spinpoint F4EG 2TB, Seagate Essentials 1TB, WD Green 500GB | Dell Perc H200+H310 HBA, HP NC550SFP 10GbE | Cooler Master MWE v2 850W | Corsair Obsidian 750d Full Tower - Behemoth12/Second Unraid Rig: HP Microserver G8 | Xeon E3-1220L V2 | Intel C204 | Hynix ECC 16GB | Matrox G200eH 16MB | WD Green 500GB NVMe |
https://linustechtips.com/topic/544122-gpu-problems/#findComment-7199090
I'll give it a shot with the PCI thing, but the others dont work 3:
Im guessing how my PSU died was that the fan on it died, then it proceeded to heat up until it melted itself 3:~
Moist
https://linustechtips.com/topic/544122-gpu-problems/#findComment-7199134
UPDATE: GOOD NEWS 3:~ ITS ALIIIVE. The top PCI-E lane is ded tho 3: So probably only running at x8..
Moist
https://linustechtips.com/topic/544122-gpu-problems/#findComment-7199227
Good news indeed. Well hopefully a replacement motherboard isn't too pricey for you, it may even still be within warranty?
Of course if you see no performance drop, it may not be too important until you next have an upgrade.
https://linustechtips.com/topic/544122-gpu-problems/#findComment-7199250
;w; I dont think I can RMA it because I dont have the CPU cover.. I didnt know I had to keep it when i built it. ;w; But it should be okay to wait.
Moist
https://linustechtips.com/topic/544122-gpu-problems/#findComment-7199306
Ah yes, that sucks. Well whenever you do upgrade, you now know to keep them. :P
https://linustechtips.com/topic/544122-gpu-problems/#findComment-7199323
