My friend just recently got a monitor for his birthday. Today he connected it to the PC, and at first it didn't seem to work. Then when he finally got it working the PC instantly bluescreened after boot. Since that the screen has been working fine, but windows won't boot on his computer. Safe mode worked, so he tried restoring his computer, but the restoration failed. Twice. Some time later windows safe mode woudn't boot at all, but he can enter the UEFI. Any idea what the problem is and how to fix it? Is it a dying hard drive? Need help!
i7-6700k. Asus Strix GTX 960 4GB. Corsair Vengeance LPX 2400mhz DDR4 16GB. Asrock z170 Pro4. Samsung 850 EVO 500GB SSD. Fsp Hyper M 600W. NZXT s340. Noctua NH-U12s
https://linustechtips.com/topic/543269-pc-stopped-working-need-help/
Sounds like a bad hard drive. I can tell you right now I almost guarantee that entire Windows installation is corrupted, if safe mode won't work theres really not much you can do it would be allot easier just to reinstall Windows.
*on a working HDD xD
Get the HDD out of his PC and try it in another one if you can.
CPU AMD Ryzen 5 5700X3D | Cooler Noctua NH-D15S | MB Asus ROG Strix B550 A-Gaming | RAM 2 x G.Skill Trident Z Royal silver 16 GB @ 3200 MHz CL14 | GPU Gigabyte GeForce RTX 3070 Vision OC 8G
Case Fractal Design Define C TG | SSD(s) Boot: Samsung 970 EVO 250 GBPrograms: Samsung 990 PRO 4 TBData: Samsung 860 EVO 500 GB | PSU Seasonic Focus GX 750W
Screen(s) Main: ViewSonic VX2758-2KP-mhd, Second: Asus PB277Q, Third: LG Flatron E2240T | Keyboard Ducky One (MX Blues) | Mouse Logitech G Pro Gaming
Sound Card: Creative Sound BlasterX AE-5 Plus, System: Edifier R1280DB | Magni/Modi Schiit Stack  | OS Windows 10, 64 Bit
Just because a HDD seems to be working doesn't mean it's not throwing errors all over without you knowing.
I meant working in the way of it being good to use with no errors. Not just the disks spinning.
If you have vessel watch tech quickies latest video! :) might help!
I agree with whats said above, try a different HDD if you have one! Does it make any wierd noises when it spins?
If you want a reply PLEASE QUOTE ME!
WE NEED CUSTOM MEMBER TITLES AGAIN!!!!!
Member title post link!
Check the basics. Run a HDD repair utility like Spinrite. Run memtest86. Most likely its just a corrupt filesystem. Boot from a Linux live CD or any boot media of your choice and back up your data first. Then format (full format, it will help check for and mark bad sectors) the drive and reinstall Windows. Need to know what the specific errors are to be able to start  pointing fingers at hardware. If you get a successful boot check event viewer for errors, and run a sfc /scannow in CMD prompt as administrator.
