3 minutes ago, NewBieToPC said:
I need help because I don't know if my cpu is even overclockable! It is a intel celeron n2830 2.16 Ghz, if it is overclockable, what should I boost it to?
if it has a k on the end of the name its over clockable
if not then nope
k=oc
non-k=no oc
e.g my i5-4440 is not overclockable since it is not unlocked
while an i7-3770K would be overclockable since it is unlocked
It's a laptop CPU so you won't be able to overclock it.
If I am right and this is a laptop processor, you shouldnt be overclocking this because laptops do not have sufficient cooling for the heat and stress your processor will be going through. If you do it, you will break your system.
  • CPU: Intel Core i7-6700k @4.3ghz, Motherboard: Gigabyte Z170X Gaming 7, RAM: Corsair Vengeance LPX 16GB @2400mhz, GPU: Gigabyte GTX 1080 G1 , Case: Corsair 300R, Storage: Samsung 850 EVO 256GB SSD, WD 1TB Black HDD, WD 2TB HDD PSU: Evga SuperNova 750 G2, Display: ASUS VG248QE @144hz, Cooling: Cooler Master V8 GTS, Keyboard: Corsair K95 RGB Platinum, Mouse: Logitech G502 Lightspeed, Sound: Phillips SHP9500 + VModa Boom Pro, Operating System: Windows 10 Pro
if not then nope
k=oc
non-k=no oc
Not entirely true as you can overclock non-k CPUs using BCLK overclocking.
if not then nope
k=oc
non-k=no oc
Not always true, on current and past platforms.
But it's a laptop ULV cpu so there's no chance anyway. Maybe via the PLL but it's a bit pointless.
:/ forgot about blck sorry :(
if not then nope
k=oc
non-k=no oc
were will it have this k
Profesional Newb
