If your 4k TV has display port than I would go with an AMD 380x for its solid value (compared to GTX 960). Furthermore due to the parallel processing power of AMD cards they actually close the gap on their Nvdia superiors.If the TV only has HDMI you must go with the Maxwell, GTX 900 series (mostly), cards since they have HDMI 2.0. Therefore either save some money to buy a 970 (trashes 390x when OCed) or go with the 380X.
PS Buying used cards can get you alot more performance for your dollar.
My TV only has HDMI so I think I should go for a 900 series card but I am concerned about the used cards itself, whether or not it has been used for bitcoin mining and whatnot. So I went online to search for new and used 970s and am thinking between gigabyte's Windforce card, MSI's Twin Frozr and the ASUS Strix card. The used and new cards barely have any price difference but I feel like the extra amount will ensure that it will work fine. Also, which of the three cards (Windforce, TWIN frozr, strix) would you recommend for no coil whining, silent performance and good overclocking?
I would recommend MSI TwinFrozer since it is quieter than the Gigabyte Windforce but still allows for good overclocking head room. The Asus Strix is the quietest (by a very slim margin) but does not overclock nearly as well as Windforce or Twin Frozer.
Used: $285  http://www.ebay.com/itm/MSI-GeForce-4GB-256-Bit-GDDR5-Graphics-Card-GTX-970-GAMING-4G-/151973741479?hash=item23625743a7:g:HqkAAOSwo6lWQXa2
New: $330 ish (New Egg)
I almost bought a 970 about a year ago (even had it in cart) but decided to hold off until 980ti released for 144Hz. I did alot of research on them and found the MSI Gaming 4G to be best all round 970. However I have a Windforce 980ti because it has the best cooling for the price.
Do you recommend waiting for the new Pascal chipsets or just straight up purchasing the 970? There have been rumors and some speculation that the Pascal chipsets will be 10 times better than Maxwell but I am not sure about the price point of Pascal.
