I heard that this was a good place to get advice on your pc build! So here goes!
This PC is NOT for gaming! Just thought I'd let you know now.
Things I've already bought:
Corsair Spec-02 ATX Case
2x4GB Corsair Vengeance DDR3 Ram (1600 Mhz)
Corsair CX600 Power Supply
WD Blue 1TB HDD
Things I'm planning to buy soon:
Intel i5-4690K Processor
MSI Z97 PC Mate Motherboard
Cryorig H7 CPU Cooler
Things I'm planning to upgrade in the future:
120GB Sandisk SSD
Gigabyte GTX 950 2GB
Cheap DVD writer
Cheap Card reader (5.25 inch bay)
2x140 MM LED Fans (My case already comes with 2x120 mm fans but I'd like some larger ones)
Gigabyte Wifi+Bluetooth PCIe card
There ya go! Yes I know it's nothing fancy.
https://linustechtips.com/topic/541184-pc-advice/
Just now, Sionji said:
Might I ask what you do plan on using this build for?
Homework, very light gaming (That's why I said it's not a gaming pc), lots and lots of programming. Also for playing music and maybe watching some youtube. I'll probably start off with Ubuntu and dual boot Windows when I get it.
https://linustechtips.com/topic/541184-pc-advice/#findComment-7165991
If you aren't going to upgrade this any time soon, the 600w power supply is pretty overkill. You could do with a much cheaper 350w and save some money. Also you might benefit from multiple monitors if you do lots of programming, and especially with a dual boot. Get a cheap graphics card with multiple display outputs for this purpose.
Edit: Saw the rest of your post. Decent power supply, I've used it it builds before.
https://linustechtips.com/topic/541184-pc-advice/#findComment-7166006
Ok, thanks for the advice.
https://linustechtips.com/topic/541184-pc-advice/#findComment-7166026
Go for a larger ssd. I would get the ssd sooner, rather than later. For the sort of work you describe it will provide a better performance boost than almost any other upgrade. You could delay the cpu cooler, using the stock cooler temporarily.
https://linustechtips.com/topic/541184-pc-advice/#findComment-7166076
Alright I'll think about it. What size would you suggest? 240GB good?
https://linustechtips.com/topic/541184-pc-advice/#findComment-7166127
