I bought a set of Primochill Revolver fittings for my build but some (about half) of the fittings are stuck together; I can't remove the top/cap/hat/whatever from the bottom half. There doesn't seem to be anywhere to grip it, either, like on my old Bits Power soft line fittings. Am I missing something? Do I just need to tighten the crap out of it then unscrew it?
https://linustechtips.com/topic/541114-separating-compression-fittings/
I always see them screwed in first, then the top removed.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
If they
If they are hardline compressions (which is what the picture looks like) then this ^ is your best bet.
If the opening is hexagonal like in some regular compressions, you need to stick a fat allan wrench/ hex key in the middle then twist the collar.
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
They are hard line fittings and that's how I separated the first half of them. When I do that with the remaining ones the whole thing comes out. The inside is completely round and the only flat spot where you'd be able to get a wrench or something on is on the lower half once you've already removed the top.
ah now I see what you mean, I was somehow confused in your build log.  If I could not get them apart any other way I would wrap that g 1/4 thread with rubber to protect the threads and gently hold it with some channel locks so you can turn the top by hand.  Other than that, maybe gently tapping them on all sides on a hard surface would let you get it by hand.  If you haven't tried that already
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
When I had that problem on the once I got, I simply used a wrench to hold the fitting then used my fingers to turn the other half.
If you need more grip then that, use 2 wrenches, 1 for each half. You might want to use something to prevent scratching the finish, just not something slippery like plastic.
I speak my mind, sorry if thats a problem.
Thought the rubber idea was interesting. Was going to get some hose from the auto parts store while I was out then remembered I have my soft tubing from my last water cooling setup.
Still left marks on the threading but it threaded so... win? Hopefully this works just as well on the rest of the fittings without damaging them as much.
ouch.  could you cut a piece of tubing open and fit it over as a second layer between the channel locks?  I'm surprised it did that.  Did the vice grips damage the top?  I would think you could twist that off by hand once you get a good grip on the base
