First thing first my configuration:
AMD R390
8gb RAM DDR3 Hyper x Fury 1866mhz x2 (16gb total)
Cooler master B700 ver. 2
Dell motherboard (still don't know the model, it's a mystery)
Intel i7 860
As you would expect, I would like to upgrade my CPU and motherboard. I would like to get a skylake processor, so the motherboard with lga 1151 socket would last for at least one more generation of CPU, but i found out that these MO doesn't support DDR3 (1.5v). So the question is, does my RAM run on a "skylake motherboard"?
If not, what should I do?
The options that I've considered are:
- i5 4690k or i7 4790 with my DRR3 RAM
- i5 6600 with DDR4 RAM (selling my actual DDR3 RAM would be a pain, because it's a recent gift...)
Thank you in advance!
https://linustechtips.com/topic/540431-cpumotherboard-advice/
i would wait till Zen launches and see if they bring anything to the table.
Rig: Thermaltake Urban S71 | MSI Z77 G45-Gaming Intel Core i5 3570K (4.4Ghz @ 1.4v) CM Hyper 212 EVO | Kingston HyperX Fury 8GB | MSI GTX 660 | Kingston 120GB SSD | Seagate 3TB HDD | EVGA 850W B2
https://linustechtips.com/topic/540431-cpumotherboard-advice/#findComment-7157444
12 minutes ago, G3rard_Bay said:
I forgot to ask about new AMD CPU's! Thank's for reading my mind! xD
Do you know the release date or expected performance?
According to some sources, the expected performance is supposed be on par or greater than skylake. but take that information with a grain of salt.
As of performance, there hasn't been any leaked performance benchmarks nor have there been an exact release date but it is expected to be released Q4 2016 or early 2016
https://linustechtips.com/topic/540431-cpumotherboard-advice/#findComment-7157563
Thanks!
But still.. Will I have to change my RAM or it's going to be 1.5v compatible?
https://linustechtips.com/topic/540431-cpumotherboard-advice/#findComment-7157594
