M-ATX Case recommendations for home NAS
Coswar
I was thinking of a cube shaped case similar to the Antec p50, but with more drive bays. Would like at least 4 3.5inch bays. Any good recommendations?
Main Rig:
AMD FX 8320 @4.5Ghz  8GB Corsair Vengeance LP Blu 1600Mhz Sapphire Vapor X HD 7950 3GB 120GB Samsung 840 Evo  Asus M5A99FX PRO R2.0
Corsair 600T Graphite Corsair H80i Corsair CX600 2x LG 24 inch LED @1080p Logitech G700s CM Quickfire TK (Brown)
Home Server:
A4 6300 @3.7Ghz 5GB Kingston/Crucial DDR3 1600Mhz 1TB WD Green 2TB Seagate Barracuda
500GB WD Blue 2x Gigabit NIC Antec 300 OCZ 500w PSU Gigabyte F2A68HM-HD2 R1.1
Node 804
PSU Tier List | CoC
Gaming Build | FreeNAS Server
Fractal node 804 would probably be a solid candidate for you.
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
Here are some options:
  1. Silverstone PS07B - $74.99 @ Newegg - 5 internal 3.5" bays
  2. Fractal Design Define Mini - $95.99 @ Newegg - 6 internal 3.5" bays and 1 5" bay that has a 5" -> 3.5" converter it comes with.
  3. Nanoxia Deep Silence 4 - $79.99 @ Amazon - 6 internal 3.5" bays (with SSD 2.5" support) - Most cube like of the 3 imo.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
If you don't mind something slightly larger, I think the Fractal Design Define R4 would be a stellar choice. It has a ridiculous amount of room for storage.
They look good especially the node 804, but any budget options?
Main Rig:
Home Server:
