okay so.. i have a logitech g430 headset, and an asus vg248qe monitor with like an audio type of io.. and I was wondering does the sound come from me plugging in my headphones into my motherboard io? or that audio type io on my monitor. if it's on the motherboard, then what does the audio jack on the monitor serve?
https://linustechtips.com/topic/539449-noob-question-about-audio/
The green port on the monitor is a line in. You will need to run a 3.5mm cable (male-to-male) from your PC audio output to that green port. Then, connect your headphones to the black audio port on the monitor. It will act as a pass through and disable the monitors built in speakers.
widget.png?style=banner2
PC: 9800X3D, 96GB Trident Z5 6200 CL28, 5090 FE, 3.84TB CM7
NAS: Xeon W-2195, 256GB ECC, 180TB Storage, 1660 Ti, TrueNAS Scale
so what you're saying is that I need an adapter to connect the audio port from my mobo io to the audio jack on the monitor? can you send me a link to that? and also my headphones has a mic line as well.. where does that go?
Those are generally a byproduct of audio through HDMI and most monitors featuring speakers.
They're meant for people who mainly use the monitor speakers but occasionally need to plug in their crappy headphones if they are making too much noise.  Don't worry about it.
AD2000x Review  Fitear To Go! 334 Review
Speakers - KEF LSX
Headphones - Sennheiser HD650, Kumitate Labs KL-Lakh
The mic line would go directly into your PC's mic port (on the back of your pc)
okay so every cable of my headphones should go into my pc port is what you're saying? i just saw a video saying it was an "audio in" and yeah.. i saw bits of green and black cords . i shouldn't worry and I should just plug the headphone cables into the pc ports yes?
Yes
Speakers - KEF LSX
