I have a problem with my western digital external hard drive (1 tb my passport) Its not functioning properly as seen below. Everything lights up well, but when i plug it, thats what happens. It doesnt even wanna show the right name with should be (My Passport). These are what i tried and its results
I tried to:
Format it: Unable to format
Open it: Either that folder freezes causing my pc to freeze/ It says insert disk
Open disk management: Its stuck at "Connecting to virtual disk" ONLY when that hard drive is plugged
Open its properties for chkdsk: It doesnt want to open and it also freezes
Format the hard drive using cmd: Unable to format also
Uninstall the driver in device manager: It never finishes, i tried leaving it to uninstall for about 5 hrs straight, yeah its still there, my guess is that it froze there.
YES I HAVE TRIED ALL THESE ON ANOTHER PC, SAME RESULT
Is there anything i can do? I dont mind wiping all the data, or losing all of it. As long as it can become usable again.
https://linustechtips.com/topic/537941-external-hard-drive-problem/
